[GRASS5] [bug #3591] (grass) d.vect.thematic (and other scripts): LC_NUMERIC setting not used in my Debian
Markus Neteler
neteler at itc.it
Thu Sep 1 08:33:59 EDT 2005
(CC Venkatesh Raghavan, Japan)
[@Venka: we try to find out how to deal with LOCALE. While merging
the GRASS 5 FOSS4G efforts into GRASS 6, I probably made a
mistake. May I ask you to help us to figure out below issue?
On Thu, Sep 01, 2005 at 01:08:09PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > >>this bug's URL: http://intevation.de/rt/webrt?serial_num=3591
> > > > >>Subject: d.vect.thematic (and other scripts): LC_NUMERIC setting not
> > > > >>used in my Debian
> > > > > GRASS doesn't use any of the locale categories except for LC_MESSAGES
> > > > > (if it was built using --with-nls).
> > > Actually, I've just noticed that it also uses LC_CTYPE (again, only if
> > > built using --with-nls):
> > > revision 1.8
> > > date: 2004/08/27 11:16:51; author: markus; state: Exp; lines: +1 -0
> > > added LC_TYPE for japanese
> > To what file do you refer?
> > Aha:
> > 2004-08-27 13:16 markus
> > * lib/gis/locale.c: added LC_TYPE for japanese
^^^^^^ - LC_CTYPE correctly
> Yep.
> > + setlocale(LC_CTYPE, "");
> > setlocale(LC_MESSAGES, "");
> > > This looks pretty dubious, as it changes the behaviour of many of the
> > > <ctype.h> functions (isalpha(), tolower() etc) as well as
> > > strcasecmp(), but GRASS' built-in string handling always assumes ASCII
> > > (e.g. G_strcasecmp() only considers A-Z/a-z regardless of the locale).
> > So, should we remove LC_CTYPE?
> I don't know. What was the reason for adding it? I know the commit
> message says "for japanese", but which functions need to use the
> locale's LC_CTYPE?
Last year I merged the GRASS 5.0/japanese changes from http://www.foss4g.org/
into GRASS 6 to enable Asian fonts etc. In GRASS 5.0 they made this
addition, so I inserted it as well in GRASS 6.
> The problem with C's locale mechanism is that it's far too coarse. It
> was a hack added to deal with the fact that the existing API functions
> had US/English conventions hardcoded into them.
> Proper localisation requires considering the "audience" for each
> individual piece of information. If you're writing something to a file
> in a standardised format, it needs to use that format's conventions
> regardless of the user's locale. If it's part of the interface text,
> it should use the user's locale.
> Other cases are less clear; e.g. what conventions (or language) should
> be used for history text? The user's locale is a reasonable guess, but
> it could well be wrong if their native language isn't the same as the
> rest of their team.
Right. E.g., here at IRST we have as many nations as people in our small
group :-) You never know which locale is used.
> > > > mlennert at moritz:~/CVS/GRASS/grass6/scripts$ grep -R LC_NUMERIC *
> > > > d.correlate/d.correlate:export LC_NUMERIC=C
> > > > d.out.png/d.out.png:export LC_NUMERIC=C
> > > > d.resize/d.resize:export LC_NUMERIC=C
> > > > d.vect.thematic/d.vect.thematic:export LC_NUMERIC=C
> > > > i.fusion.brovey/i.fusion.brovey:export LC_NUMERIC=C
> > > [snip]
> > > > So it is used quite a lot in scripts.
> > > In all cases, it's forced to "C", which is the same as it not being
> > > used. Scripts do this to prevent other programs (e.g. awk) from using
> > > the user's LC_NUMERIC settings, so that they don't end up passing
> > > floating-point values which use a comma to programs which expect a
> > > dot.
> > I have added it everywhere upon your suggestion:
> > http://grass.itc.it/pipermail/grass5/2005-March/017637.html
> > Maybe a misunderstanding. What do do now?
> Find out why the setlocale(LC_CTYPE, "") was needed for Japanese.
Will do.
> If it's due to a few specific function calls, we should probably be
> doing e.g.:
> do_something(...);
> setlocale(LC_CTYPE, "C");
> Glynn Clements <glynn at gclements.plus.com>
OK, thanks.
Maybe Venkatesh has an idea or can contact the person who inserted
LC_CTYPE in lib/gis/locale.c for japanese.
Markus
