[GRASS5] rgb color support in ps.map ?
Moritz Lennert mlennert at club.worldonline.be
Mon Sep 5 05:42:59 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Michael Barton wrote:
> I'm sure that the updates discussed will be very helpful to many.
> I'd like to list a request in a little different direction however, that I
> think would help even more people.
> Is there any way to create a postscript output driver for a monitor window?
> Sending a monitor window (at whatever its current resolution is) to a
> postscript file, and then to a printer, would be very useful. This could
> work like d.png. But even doing it as graphic output (rather than the nicer
> ps.map output) would be a big help to many.
In order to get (vector) postscript output, I use d.vect.thematic,
save the results as a group and then use the printing dialog in the
GIS Manager to print it to postscript.
It would also be possible to directly create a ps.map instructions
file from d.vect.thematic, but this seems to be overkill since the
printing dialog exists.
However, some d.vect commands are not implemented in ps.map (e.g.
d.vect.chart), so this solution is obviously limited.
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDHBMjrIrMbm76jD8RArT3AJ9rHVmGvfOEn1A4ERwo1VBWuFLdJQCeKcac
MErlO1Hc3wgFlRsKppTPVvo=
=wOrq
-----END PGP SIGNATURE-----
