[GRASS5] New script for monitor output to multiple formats
Soeren Gebbert
soeren at pool.math.TU-Berlin.DE
Tue Sep 6 06:18:33 EDT 2005
On Sun, 4 Sep 2005, Michael Barton wrote:
> Colleagues and co-conspirators
> I¹d like those of you with different systems to test this script if you
> could. As part of my updates to the GIS Manager, I¹ve expanded the
> functionality of d.out.png.
I have tested the script on PIII 450Mhz 192MB Linux Debian Testing with
grass6.1-cvs and AMD 3000+ 32Bit 512MB Linux Fedora Core 3 with
grass6.1-cvs.
The script works well, i've tested every output format but not
every resolution with every outputformat, only with tif and png.
I've used the spearfish dataset and visualized raster maps, vectors,
labels and the scalarbar. Looks good, but the black or transparent background
didnt worked. I watched the pictures with gimp 2.something.
Besides background and transparency the script work very well.
Best regards
Soeren
> The script I¹ve attached hered.out.filewill export the current display
> monitor to several different file formats: PNG and PPM (using Glynn¹s update
> of the PNG driver) from the PNG driver, and to TIFF, JPEG, and BMP using
> gdal_translate. PNG compression, JPEG compression, and selections for
> transparent background, white (now default), and black backgrounds are
> supported.
> If this works OK on other systems besides my Mac (OSX 10.4), I¹ll add it to
> the CVS to replace d.out.png.
> Thanks much
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
