[GRASS5] ps.map symbol size from DB column
Hamish
hamish_nospam at yahoo.com
Wed Sep 7 02:41:03 EDT 2005
> > Hi,
> > I have done most of the code for getting ps.map to do dynamic
> > symbol/eps sizing from a DB column, following the d.vect.chart
> > interface.
Radim:
> See v.to.rast, it is necessary to select all cat/value
> pairs in one query (otherwise it is slow).
> db_select_CatValArray()
> db_CatValArray_get_value_int() / db_CatValArray_get_value_double()
Great. It is now done and in CVS. Screenshot of PostScript file
attached. Probably needs some testing.
The new commands for the vpoints instruction are sizecol and scale.
happy mapping,
Hamish
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050907/d087486b/sizecol.png
