[GRASS5] Re: r.sun parameter descriptions
Jaro Hofierka hofierka at geomodel.sk
Tue Sep 13 01:42:32 EDT 2005
Hamish wrote:
> Hi,
> the following change improved the r.sun parameter descriptions somewhat:
> grass6/raster/r.sun/main.c
>   http://grass.itc.it/pipermail/grass-commit/2005-March/016953.html
> but left many option desciptions ending with "[-]" (e.g. albedo).
> Should these be replaced with [0-1] ?
> add to opt->options or (0 <= x <= 1) checks in the C code?
A hyphen in the brackets explains that the parameter has no units.
Albedo is within <0-1> range but Linke turbidity factor has no strict
limits. It typically ranges between 3 (clear skies) to 7 (heavily
polluted skies).
> Anyone have plans or thoughts about migrating to the SOLPOS algorithm?
> What sort of improvement would this bring? i.e. is the difference large
> enough to matter in a practical sense or is it more an academic matter
> of making the model as correct as it can be?
As far as I know nobody is working on this. Thomas Huld from JRC in
Ispra has made several changes and improvements for a shadowing
algorithm, but it's not ready for a CVS upload. We have some discussions
on some issues and it needs more testing.
Jaro
> thanks,
> Hamish
