[GRASS5] Re: [PATCH] introduce where clause in d.vect.thematic
(and v.univar.sh)
Hamish
hamish_nospam at yahoo.com
Tue Sep 13 07:09:50 EDT 2005
> > By all means, do it. Also, you might want to take a look at
> > http://grass.itc.it/pipermail/grass5/2005-June/018589.html and I
> > might try to integrate that too once Moritz makes his changes.
> Ok, I've committed the changes to introduce a where option. As soon
> as (if) Hamish manages to find some time to allow rgb colors for
> rectangles in ps.map, I will also activate the dormant code
> concerning a ps legend.
I have just updated things so that the ps.map 'point' command now
accepts standard named colors, RGB triplets, and "none" as valid
input for both border and fill color.
The 'vpoints' command already had this functionality.
Also 'rectangle', 'line', and 'region' have been updated for RGB.
Note 'region' was broken, since at least the first CVS entry in 1999.
Now fixed in all branches.
have fun,
Hamish
