[GRASS5] r.profile
Hamish
hamish_nospam at yahoo.com
Tue Sep 13 21:21:51 EDT 2005
> is there a way to feed profile-coordinates into r.profile through a
> file instead of stating them on the command line ?
> cat mycoordinates.txt |r.profile input=foo output=bat profile=-
> and similar approaches do not seem to work.
use a shell script:
for coord in `cat mycoord.txt` ; do
east1=`echo $coord | cut -f1 -d'|'`
north1=`echo $coord | cut -f2 -d'|'`
east2=`echo $coord | cut -f3 -d'|'`
north2=`echo $coord | cut -f4 -d'|'`
echo >> output.txt
echo "LINE: [$east1, $north1 ; $east2, $north2]" >> output.txt
r.profile input=foo output=- \
profile=$east1,$north1,$east2,$north2 >> output.txt
done
that assumes format of mycoord.txt is "east1|north1|east2|north2"
Hamish
