[GRASS5] r.profile
Bob Covill
bcovill at tekmap.ns.ca
Wed Sep 14 11:12:12 EDT 2005
Helena & Hamish,
I sent Peter a test version of r.profile this morning that allows
coordinates to be piped in. Basically coordinates could be provided in
three ways ...
coords from file
cat mycoordinates.txt | r.profile input=foo output=bat
select coords interactively
r.profile -i input=foo output=bat
coords on command line
r.profile input=foo output=bat profile=e,n,e,n,...
If you are interested I can make this available for testing.
Bob
Helena Mitasova wrote:
> Hamish, could this be incorporated into r.profile or at least provided
> as a script? There are many applications where this capability is needed
> and I am sure that many users would appreciate it (especially those who
> work with coastal data, including myself).
> thanks, Helena
> Hamish wrote:
>>> is there a way to feed profile-coordinates into r.profile through a
>>> file instead of stating them on the command line ?
>>> cat mycoordinates.txt |r.profile input=foo output=bat profile=-
>>> and similar approaches do not seem to work.
>> use a shell script:
>> for coord in `cat mycoord.txt` ; do east1=`echo $coord | cut -f1
>> -d'|'`
>> north1=`echo $coord | cut -f2 -d'|'`
>> east2=`echo $coord | cut -f3 -d'|'`
>> north2=`echo $coord | cut -f4 -d'|'`
>> echo >> output.txt
>> echo "LINE: [$east1, $north1 ; $east2, $north2]" >> output.txt
>> r.profile input=foo output=- \
>> profile=$east1,$north1,$east2,$north2 >> output.txt
>> done
>> that assumes format of mycoord.txt is "east1|north1|east2|north2"
>> Hamish
