[GRASS5] connecting a table to a view in pg driver
Radim Blazek
radim.blazek at gmail.com
Thu Sep 15 04:26:40 EDT 2005
On 9/14/05, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello,
> Is it possible to connect a map to a view in postgres ? I get :
> > v.db.connect -o bxlgdsec table=vespvie
> WARNING: Table <vespvie> does not exist in database <grass>
> WARNING: The table <vespvie> is now part of vector map <bxlgdsec>
> and may be deleted or overwritten by GRASS modules.
> Does this mean it is not possible, or that I am doing something wrong ?
It is only warning, the connection is created.
> Moritz
> P.S. Is it a bug or a feature that v.db.connect registers the
> connection to a nonexisting table ? Shouldn't it fail and leave the
> settings as before the command ?
No, it is feature, GRASS always does what you want, only if
it seems to be strange, it prints a warning. Thanks to this feature
you can work with view.
The bug is, that it does not check also available views.
Radim
