[GRASS5] trouble with vector layers
Radim Blazek radim.blazek at gmail.com
Thu Sep 15 10:16:44 EDT 2005
Can you send output from:
v.category input=molenbeek option=report
Radim
On 9/15/05, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello,
> Don't know if this is a bug or if I just don't understand the use of
> layers:
> GRASS 6.1.cvs (BELGIQUE):~ > v.db.connect -p molenbeek
> Vector map <molenbeek> is connected by:
> layer <1> table <molenbeek> in database <grass> through driver <pg>
> with key <cat>
> layer <2> table <molpoptot> in database <grass> through driver <pg>
> with key <cat>
> the cat column is identical in the two tables. However:
> GRASS 6.1.cvs (BELGIQUE):~ > d.vect molenbeek where='cat>8000'
> displays the right areas, but
> GRASS 6.1.cvs (BELGIQUE):~ > d.vect molenbeek layer=2 where='cat>8000'
> does not display anything. At the same time
> v.db.select molenbeek layer=2 where='cat>8000'
> correctly lists the corresponding lines in the table molpoptot.
> Moritz
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.1 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFDKTUarIrMbm76jD8RAucEAJ9LTNlJWobyEg98Kc2xl0wZlWkbTACdG483
> v0POBQi73maZ713WpBlB16s=
> =FVva
> -----END PGP SIGNATURE-----
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
