[GRASS5] SQLite
Martin Landa
landa.martin at gmail.com
Fri Sep 16 06:52:10 EDT 2005
Hi Radim,
in select.c and globals.h are '//' comments ... it is only a small note ...
really good work, thanks for it,
Martin
On 9/16/05, Radim Blazek <radim.blazek at gmail.com> wrote:
> On 9/16/05, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> > Cool !
> > Does this driver implement the entire sqlite sql subset ?
> The driver only passes queries to SQLite so it should do everything
> what SQLite does. Indexes on cat column are created automaticaly.
> Radim
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
