[GRASS5] GRASS_STDERR vs. email
Fri Sep 23 12:47:07 EDT 2005
William Kyngesburye wrote:
> I've long since removed that from the build instructions, and from my
> setup.  Since I left the GIS_ERROR_LOG, I still get errors logged
> there, of course.
> I'm pretty sure that was a GRASS variable at one time - I was
> confused about shell vs. GRASS vars at one time so I made sure I got
> it right.  And when then email thing was the way it used to be, I did
> it this way and it worked.
It's always been an environment variable. However, at one time, all
GRASS variable settings in $GISRC were added to the environment at
startup, so you could set an environment variable in $GISRC and it
would work. This is no longer true.
