[GRASS5] some new r3.* modules and updates in grass6.1-cvs
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Sep 28 14:17:29 EDT 2005
I just tested r3.out.rast and r3.in.rast (we would like to use it to
store time series output from simwe).
It seems to work well, but r3.in.rast is not in the current CVS - is
anybody planning to add it? I can do it if there is nobody who can do it
faster than me. I got it from here:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
Soeren, thank you very much for this - it should make managing numerous
sets of time series much easier,
Helena
Soeren Gebbert wrote:
> Hi all,
> i've made some changes to the following modules and implemented a new
> one in the current grass6.1-cvs:
> Updates:
> g.mremove
> * added rast3d support
> r3.to.rast
> * better error handling (G_unopen_cell)
> r3.out.vtk
> * added new flag "-o" -- the scalefactor effects the origin
> r.out.vtk
> * documentation update
> * added new flag "-p" -- pointdata support if no elevation map is given
> * added new option -- elevation value for 2D data
> New module:
> r3.in.rast
> * converts 2d raster maps into one G3D map
> * the number of 2D maps can be less than the depths of the G3D region, the
>   last 2D map is used to fill the G3D raster
> This module works only if the G3D resolution is equal to the current
> window resolution.
> Thats all for the moment.
> I want to implement a new module which produces cross-section 2D maps
> from a G3D map by a given 2D elevation map.
> All modules and diffs (for CVS) are available at:
> Because i have no CVS write access, it would be nice if somebody with
> write access can add the changes to the cvs. The needed diff's are
> available at my homepage (the link above).
> It would be great too,
> if somebody can test these modules, because i have only 2 test datasets.
> The modules are working fine at my machine (Fedora Core 3 Linux 32bit
> kernel 2.6.12, AMD 3000+ 512Mb RAM, grass6.1-cvs), but please use only
> testdatasets to prevent damage on your data, because im not able to
> emulate all errors which i try to handle ... .
> Feel free to send me any comments, hints and critism about the modules.
> Best regards
> Soeren Gebbert
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
