[GRASS5] [bug #3695] (grass) r.to.vect -- D3/5: new node = 3101610, n_noKilled
Request Tracker
grass-bugs at intevation.de
Thu Sep 29 05:15:47 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3695
Subject: r.to.vect -- D3/5: new node = 3101610, n_noKilled
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs 26.08.05
Hello,
r.to.vect produced after approx. 24 hours the error message "D3/5: new node =
3101610, n_noKilled" (full output see below).
r.info of the input file "vcf_1" gives:
Type of Map: raster
Number of Categories: 253
Data Type: CELL
Rows: 3797
Columns: 6905
Total Cells: 26218285
Projection: Lambert Azimuthal Equal Area (zone 0)
N: 1728000 S: -170500 Res: 500
E: 1634500 W: -1818000 Res: 500
Range of data: min = 0 max = 253
exactly the same file but with just 8 categories works fine.
r.to.vect input=vcf_1 output=vcf_1v
feature=area -vs
D3/5: new node = 3101608, n_nodes = 3101608, alloc_nodes = 3102000
D3/5: Add new node: 3101608
D3/5: dig_node_add_line(): node = 3101608 line = 4546923
D3/5: dig_node_alloc_line(): add = 1
D3/5: angle = -9.000000
D3/5: dig_node_add_line(): line 4546923 added position 0 n_lines: 1 angle
-9.000000
D3/5: dig_spidx_add_line(): line = 4546923
D3/5: dig_cidx_add_cat(): field = 1 cat = 13 line = 4546923 type = 8
D3/5: Vect_read_next_line()
D3/5: V1_read_next_line_nat()
D3/5: Vect__Read_line_nat: offset = 449391157
D3/5: type = 8, do_cats = 1 dead = 0
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 449391186
D3/5: Register line: offset = 449391157
D3/5: Register node: type = 8, -197250.000000,984250.000000
D3/5: dig_find_node()
D3/5: node = 0
D3/5: dig_add_node(): n_nodes = 3101608, alloc_nodes = 3102000
D3/5: dig_spidx_add_node(): node = 3101609, x,y,z = -197250.000000,
984250.000000, 0.000000
D3/5: new node = 3101609, n_nodes = 3101609, alloc_nodes = 3102000
D3/5: Add new node: 3101609
D3/5: dig_node_add_line(): node = 3101609 line = 4546924
D3/5: dig_node_add_line(): line 4546924 added position 0 n_lines: 1 angle
-9.000000
D3/5: dig_spidx_add_line(): line = 4546924
D3/5: dig_cidx_add_cat(): field = 1 cat = 20 line = 4546924 type = 8
D3/5: Vect__Read_line_nat: offset = 449391186
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 449391215
D3/5: Register line: offset = 449391186
D3/5: Register node: type = 8, -196750.000000,984250.000000
D3/5: node = 0
D3/5: dig_add_node(): n_nodes = 3101609, alloc_nodes = 3102000
D3/5: dig_spidx_add_node(): node = 3101610, x,y,z = -196750.000000,
G
-------------------------------------------- Managed by Request Tracker
