[GRASS5] monitor resize
Fri Sep 30 21:31:28 EDT 2005
> > I have a question. I remember I was able to resize the XDRIVER
> > monitor by dragging the edge of the window with mouse.  But now I
> > cannot, maybe from 6.0 (?).  Is this intended (then why?) or a
> > window manager problem? I know there is d.resize, but it's sometimes
> > inconvenient.
> You cannot resize the window while a client is connected. The
> dimensions which the driver reports to the client must remain correct
> for the lifetime of the client.
> However, there have been reported problems with some window managers
> refusing to allow resizing even when no client is connected. The most
> likely reason is that they are recording the min/max size which are
> set while a client is connected then continuing to enforce the
> restrictions after they are removed.
> One thing to try is to change:
> 	szhints->flags = PSize;
> to:
> 	szhints->flags = 0;
> on line 24 of display/drivers/XDRIVER/XDRIVER24/Client.c, and/or
> changing:
>     szhints->flags = USSize;
> to:
>     szhints->flags = 0;
> on line 205 of display/drivers/XDRIVER/XDRIVER24/Graph_Set.c.
> Let me know how this works out; the existing code works OK with all of
> the window managers which I have tried.
Using the Fluxbox WM (~1 year old version) on Debian:
The resizing control (and window border) are there when you first create
the window with d.mon, but disappear as soon as you call anything (eg
d.erase). `d.mon stop=xN && d.mon start=xN` doesn't always bring them
back unless you start/stop a different number monitor first.
The above two code changes don't have any affect, AFAICT.
Are there any verbose xwininfo options that may be of help for checking
the window's state?
Hamish
