[GRASS5] [bug #4239] (grass) d.vect: lines with no category are not displayed
Martin Landa landa.martin at gmail.com
Tue Apr 4 08:02:13 EDT 2006
maybe the attached patch will fix this problem (I hope) ...
Best regards,
Martin
2006/4/4, Request Tracker <grass-bugs at intevation.de>:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4239
> Subject: d.vect: lines with no category are not displayed
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 2006-03-29
> With Grass 6.1 CVS 2006-03-29 I can't display lines/boundaries which don't have a category.
> To reproduce:
> In v.digit create a line/boundary with no category, exit, display - and nothing will be displayed.
> Or do v.in.region type=line and then display the result - nothing is displayed. Once you open the laye v.digit lines will become visible.
> Qgis displays lines without categories allright.
> Maciek
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060404/655acb73/d_vect_no_cats.diff.gz
