[GRASS5] G_command_history()
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Apr 4 23:41:48 EDT 2006
On Apr 4, 2006, at 9:54 PM, Hamish wrote:
> If there are any modules you think should be updated to use
> G_command_history() before 6.2.0, please mention them now.
> (saves the command line into the map's meta-data history file)
> In the future we can consider whether all modules that make a
> raster map
> should use it, but for now as the priority I will only consider
> modules
> like r.sun, r.patch, or v.surf.rst who have a number of input params
> which are critical to record.
I have submitted it for v.surf.rst in january, thanks to Jaro for
adding it
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/rst/interp_float/
> output2d.c
Helena
> Please check that it hasn't already been done before suggesting... :)
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
