[GRASS5] Problems compiling and running GRASS6.CVS
Glynn Clements
glynn at gclements.plus.com
Wed Apr 5 20:39:36 EDT 2006
Glynn Clements wrote:
> I intend to remove the references to CFLAGS_WARNING; the user should
> use CFLAGS as above to select the warning switches.
OK, I've removed the following automated flags from Platform.make.in:
CFLAGS_DEBUG
CFLAGS_OPTIMIZE
CFLAGS_WARNING
LDFLAGS_DEBUG
LDFLAGS_OPTIMIZE
Of these, only CFLAGS_WARNING was actually being used.
The user can still add flags by setting CFLAGS, CXXFLAGS, and LDFLAGS
when running configure.
