[GRASS5] [bug #4258] (grass) v.kernel is too slow on large point datasets
Request Tracker
grass-bugs at intevation.de
Thu Apr 6 15:50:46 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4258
Subject: v.kernel is too slow on large point datasets
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: CVS HEAD checked out 20060406
v.kernel is too slow on large point datasets because it does not use spatial index. The following patch enables the spatial index. Speed improvement is in the range of 100x for datasets with more than a thousand points.
Index: main.c
RCS file: /home/grass/grassrepository/grass6/vector/v.kernel/main.c,v
retrieving revision 1.9
diff -u -r1.9 main.c
--- main.c 9 Feb 2006 03:09:06 -0000 1.9
+++ main.c 6 Apr 2006 19:39:57 -0000
@@ -584,36 +584,50 @@
void compute_distance( double N, double E, struct Map_info *In,
double sigma, double term, double *gaussian, double dmax)
- int line, nlines, ltype;
+ int line, nlines;
double a[2],b[2];
double dist;
+ /* spatial index handling, borrowed from lib/vector/Vlib/find.c */
+ BOUND_BOX box;
+ static struct ilist *NList = NULL;
static struct line_pnts *Points = NULL;
- if (!Points)
- Points = Vect_new_line_struct ();
a[0] = E;
a[1] = N;
+ if (!NList)
+ NList = Vect_new_list ();
+ if (!Points)
+ Points = Vect_new_line_struct ();
+ /* create bounding box 2x2*dmax size from the current cell center */
+ box.N = N + dmax;
+ box.S = N - dmax;
+ box.E = E + dmax;
+ box.W = E - dmax;
+ box.T = HUGE_VAL;
+ box.B = -HUGE_VAL;
+ /* number of lines within dmax box */
+ nlines = Vect_select_lines_by_box (In, &box, GV_POINT, NList);
*gaussian=.0;
- nlines = Vect_get_num_lines(In);
+ for ( line = 0; line < nlines; line++ ) {
- /* TODO ? : use spatial index */
- for ( line = 1; line <= nlines; line++){
- ltype = Vect_read_line (In, Points, NULL, line);
- if ( !(ltype & GV_POINT ) ) continue;
+ Vect_read_line (In, Points, NULL, NList->value[line]);
- b[0] = Points->x[0];
- b[1] = Points->y[0];
+ b[0] = Points->x[0];
+ b[1] = Points->y[0];
- dist = euclidean_distance(a,b,2);
+ dist = euclidean_distance(a,b,2);
- if(dist<=dmax)
- *gaussian += gaussianKernel(dist/sigma,term);
+ if(dist<=dmax)
+ *gaussian += gaussianKernel(dist/sigma,term);
-------------------------------------------- Managed by Request Tracker
