[GRASS5] [bug #4264] (grass) Problem in r.le.setup
Sat Apr 8 00:57:34 EDT 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4264
> Subject: Problem in r.le.setup
> Platform: Mac OSX
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 20060401
> r.le.setup is a port from Grass 5.0 and it has two problems.
> 1) It requires a site file (optional) that does not exist in new Grass
> 6.x format 2) After required files I have to press Ctrl+C to enter in
> r.le.setup menu.
no answer, but is "r.li" intended as a full replacement for r.le? (ie
will r.le be removed once r.li is working?)
Maybe focus development work on getting that ready instead.
 http://article.gmane.org/gmane.comp.gis.grass.devel/10259
 http://article.gmane.org/gmane.comp.gis.grass.devel/11323/
Hamish
