[GRASS5] [bug #4246] (grass) NVIZ: segfault in kanimation panel
Harmish Bowman via RT grass-bugs at intevation.de
Sat Apr 8 07:10:46 EDT 2006
re. segfault in nviz if you use a d.nviz generated script:
G61> nviz script=somefile.nvsrc
The segfaults happens when it tries to add a keyframe:
visualization/nviz/src/anim_support.c
line ~410 in  Nadd_key_cmd()
   G_free (listels);
if I comment that line out, the script runs, nviz loads, and all is good.
printf(%p) shows listels at 0xbfffee6c
I notice in the compiler warnings:
anim_support.c:367: warning: passing arg 4 of `Tcl_SplitList' from
incompatible pointer type
which is this:
    if (Tcl_SplitList(interp, argv[2], &numels, &listels) != TCL_OK)
is that call promoting listels to something else?
Is there a better way of debugging nviz than just peppering puts and printf's?
gdb is useless for it.
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
