[GRASS5] [bug #4270] (grass) v.in.ascii field separator
Request Tracker grass-bugs at intevation.de
Sat Apr 8 13:26:20 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4270
Subject: v.in.ascii field separator
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 6.1.cvs-2006.04.08
hello!
working with v.in.ascii via GUI I noticed that:
for the field separator, you now need to define it for example as ';' (previously it worked as simple ;), but this is inconsistent with the column field.
what about rewriting the field explanation adding a small example instead of just "Field separator", providing a hint similarly to the columns definition field?
thanks!
ciao!
giorgio
-------------------------------------------- Managed by Request Tracker
