[GRASS5] v.digit segfault
ivan marchesini marchesini at unipg.it
Thu Apr 13 03:41:44 EDT 2006
I will try in few moments!!!!
thank you
Il giorno gio, 13/04/2006 alle 12.18 +1200, Hamish ha scritto:
> > I'm using grass 6.1-cvs on a Debian-unstable
> > I have just done the cvd update
> > I have compiled using:
> > ______________________________________________________________________
> > CFLAGS="-g -Wall" ./configure
> > --with-tcltk-includes=/usr/include/tcl8.4
> > --with-postgres-includes=/usr/include/postgresql --with-nls
> > --with-sqlite --with-freetype-includes=/usr/include/freetype2
> > --with-freetype --with-cxx --enable-largefile
> > However now I have a problem when I try to use v.digit
> > I obtain segmentation fault!!
> > GRASS 6.1.cvs (gauss_boagaEST):~ > v.digit -n pippo2
> > D2/5: Scale = 5.491174
> > D2/5: display_map()
> > D2/5: set color to symb 2: 255 255 0
> > D2/5: set color to symb 13: 0 153 0
> > D2/5: set color to symb 12: 255 0 0
> > D5/5: driver_close()
> > D5/5:  -> closed
> > Segmentation fault
> Does the same thing happen if you compile against tcl/tk 8.3-dev?
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
jabber: geoivan73 at jabber.org
