[GRASS5] [bug #4291] (grass) v.in.ascii memory faults with only two columns.
Request Tracker
grass-bugs at intevation.de
Fri Apr 14 12:32:50 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4291
Subject: v.in.ascii memory faults with only two columns.
I'm using a recent (past couple of days) self compiled CVS grass on Ubuntu
(debian).
v.in.ascii will not import a file with just two columns. It imports the same
data correctly if there are more columns to the right.
Output:
v.in.ascii input=ascii-test.csv output=ascii_test fs=, skip=1
Maximum input row length: 8
Maximum number of columns: 2
Minimum number of columns: 2
*** glibc detected *** malloc(): memory corruption: 0x0809b1b8 ***
Aborted
Download test case:
http://www.shockfamily.net/cedric/grass/ascii-test.csv
Thanks for the help,
Cedric
-------------------------------------------- Managed by Request Tracker
