[GRASS5] Why does v.label require an x display?
Hamish
hamish_nospam at yahoo.com
Sat Apr 15 21:00:41 EDT 2006
> I¹m working with creating a TclTk version of d.label to make postscript text
> labels (rather than raster text labels) available in the GIS Manager.
> I just tried v.label to make a new set of labels and found that it won't run
> unless an x display is open. No need to have anything showing in the x
> display, it just has to be open.
> Is this really necessary? If not, can it be changed?
my fault, I'll see if I can change it.
if(FontSize->answer) {
fontsize = atoi(FontSize->answer);
/* figure out space param dynamically from current dispay */
if(Along_flag->answer) {
if (R_open_driver() != 0) /* connect to the driver */
G_fatal_error(_("No graphics device selected"));
/* Read in the map region associated with graphics window */
D_setup(0);
space = fontsize / D_get_u_to_d_xconv(); /* in earth units */
R_close_driver();
else
fontsize = 0;
Hamish
