[GRASS5] Hex equivalents of grass colors?
Michael Barton
michael.barton at asu.edu
Sun Apr 16 00:58:41 EDT 2006
Thanks. This will be helpful. Should I stick a translation procedure into
gm.tcl, or put it elsewhere?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Cedric Shock <cedricgrass at shockfamily.net>
> Date: Sat, 15 Apr 2006 18:14:09 -0700
> To: <grass5 at grass.itc.it>
> Cc: Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS5] Hex equivalents of grass colors?
> Michael,
>> Is there some kind of lookup available for the hex equivalent of standard
>> grass colors (red, violet, etc)? Lacking that, is there an RGB lookup that
>> I could translate to hex?
> This is information is on my wish list too. I found it in:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/gis/color_str.c
> {"white", 255, 255, 255},
> {"black", 0, 0, 0},
> {"red", 255, 0, 0},
> {"green", 0, 255, 0},
> {"blue", 0, 0, 255},
> {"yellow", 255, 255, 0},
> {"magenta", 255, 0, 255},
> {"cyan", 0, 255, 255},
> {"aqua", 100, 127, 255},
> {"grey", 127, 127, 127},
> {"gray", 127, 127, 127},
> {"orange", 255, 127, 0},
> {"brown", 180, 75, 25},
> {"violet", 255, 0, 255},
> {"indigo", 0, 127, 255}
> And of course the red:green:blue format and NONE / none / NonE whatever
> returns the special no color.
> I've been playing with colors a bit too. I have a little rgb/his color system
> color picker that has sliders for red, green, blue, hue, intensity, and
> saturation. This is possible since, although neither rgb or his is an
> absolute color space, they are remappings of the same color model.
> This code snippet takes integer red green and blue values on [0,255] to a hex
> color for tcl:
> set rX [format %02X $red]
> set gX [format %02X $green]
> set bX [format %02X $blue]
> set color "#$rX$gX$bX"
> --Cedric
