[GRASS5] Hex equivalents of grass colors?
Michael Barton michael.barton at asu.edu
Sun Apr 16 03:58:33 EDT 2006
OK. Using Glynn's version of RGB equivalents for GRASS colors, below is a
TclTk procedure to convert to hex.
Cedrick,
Do you want to put it into gui.tcl? How to reference it from other routines?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
##### grass colors to hex in TclTk
proc { gcolor } {
    switch $gcolor {
        "white" {
            set xcolor "#ffffff"
        "black" {
            set xcolor "#000000"
        "red" {
            set xcolor "#ff0000"
        "green"{
            set xcolor "#00ff00"
        "blue" {
            set xcolor "#0000ff"
        "yellow" {
            set xcolor "#ffff00"
        "magenta" {
            set xcolor "#ff0080"
        "cyan" {
            set xcolor "#00ffff"
        "aqua" {
            set xcolor "#6480ff"
        "grey" {
            set xcolor "#afafaf"
        "gray" {
        "orange" {
            set xcolor "#ff8000"
        "brown" {
            set xcolor "#b44d19"
        "violet" {
            set xcolor "#ff00ff"
        "indigo" {
            set xcolor "#0080ff"
    return $xcolor
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sun, 16 Apr 2006 06:14:58 +0100
> To: Cedric Shock <cedricgrass at shockfamily.net>
> Cc: <grass5 at grass.itc.it>, Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS5] Hex equivalents of grass colors?
> Cedric Shock wrote:
>> Michael,
>>> Is there some kind of lookup available for the hex equivalent of standard
>>> grass colors (red, violet, etc)? Lacking that, is there an RGB lookup that
>>> I could translate to hex?
>> This is information is on my wish list too. I found it in:
>> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/gis/color_str.c
>>     {"white",   255, 255, 255},
>>     {"black",     0,   0,   0},
>>     {"red",     255,   0,   0},
>>     {"green",     0, 255,   0},
>>     {"blue",      0,   0, 255},
>>     {"yellow",  255, 255,   0},
>>     {"magenta", 255,   0, 255},
>>     {"cyan",      0, 255, 255},
>>     {"aqua",    100, 127, 255},
>>     {"grey",    127, 127, 127},
>>     {"gray",    127, 127, 127},
>>     {"orange",  255, 127,   0},
>>     {"brown",   180,  75,  25},
>>     {"violet",  255,   0, 255},
>>     {"indigo",    0, 127, 255}
> However, this doesn't exactly match the colours used by the display
> drivers. Both the PNG and X drivers use:
> LIB_assign_standard_color(RED,     DRV_lookup_color(255,   0,   0));
> LIB_assign_standard_color(ORANGE,  DRV_lookup_color(255, 128,   0));
> LIB_assign_standard_color(YELLOW,  DRV_lookup_color(255, 255,   0));
> LIB_assign_standard_color(GREEN,   DRV_lookup_color(  0, 255,   0));
> LIB_assign_standard_color(BLUE,    DRV_lookup_color(  0,   0, 255));
> LIB_assign_standard_color(INDIGO,  DRV_lookup_color(  0, 128, 255));
> LIB_assign_standard_color(VIOLET,  DRV_lookup_color(255,   0, 255));
> LIB_assign_standard_color(BLACK,   DRV_lookup_color(  0,   0,   0));
> LIB_assign_standard_color(WHITE,   DRV_lookup_color(255, 255, 255));
> LIB_assign_standard_color(GRAY,    DRV_lookup_color(175, 175, 175));
> LIB_assign_standard_color(BROWN,   DRV_lookup_color(180,  77,  25));
> LIB_assign_standard_color(MAGENTA, DRV_lookup_color(255,   0, 128));
> LIB_assign_standard_color(AQUA,    DRV_lookup_color(100, 128, 255));
> The main differences are for magenta and grey. The driver's magenta is
> definitely wrong, as magenta is supposed to be one of the corners of
> the RGB cube; maybe those values should be used for violet?
