[GRASS5] Color prompt partially implemented, color confusion.
Helena Mitasova
hmitaso at unity.ncsu.edu
Sun Apr 16 20:26:36 EDT 2006
The following are my suggestions - I vote for consistency - the
changes needed are
relatively small so they should not dramatically change expected
color tables:
> Differences in named color definitions:
> G_str_to_color ignores case.
> D_translate_color is case sensitive
> name D_translate_color G_str_to_color
> red 255 0 0 same
change 127 -> 128
> orange 255 128 0 255 127 0
> yellow 255 255 0 same
> green 0 255 0 same
> blue 0 0 255 same
change 127->128
> indigo 0 128 255 0 127 255
this is really magenta - violet should be 128 0 255
> violet 255 0 255 same (this is a strange violet)
> black 0 0 0 same
> white 255 255 255 same
> gray 175 175 175 127 127 127
> brown 180 77 25 same
this should be 255 0 255
> magenta 255 0 128 255 0 255 (D_ has a very strange
> magenta)
> aqua 100 128 255 100 127 255
> grey lookup to gray 127 127 127
> cyan doesn't exist 0 255 255
there are some issues with grey and gray that I don't remember ,
maybe gray as 175 and grey 127 would work?
> How should we straighten out these colors?
others may have different suggestions,
Helena
> --Cedric
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
