[GRASS5] Color code cleanup
Glynn Clements
glynn at gclements.plus.com
Tue Apr 18 05:02:50 EDT 2006
Cedric Shock wrote:
> Definitions of the rgb values for preallocated ("standard") colors are now in
> colors.h. The major color related code (D_translate, G_str_to_color, and the
> definitions of color tables in XDRIVER and PNG) have been updated to use
> this. I haven't updated the named_colr.c code because I don't have an easy
> way to test it. I haven't touched the postscript code, as it is quite
> dissimilar.
If you've touched the colour-handling code in the display driver or
libraries, please test the changes on a colour-mapped display (e.g.
"startx -- :1 -depth 8 -cc 3").
