[GRASS5] Color prompt partially implemented, color confusion.
Glynn Clements
glynn at gclements.plus.com
Tue Apr 18 11:20:33 EDT 2006
Glynn Clements wrote:
> > If we also have standard_color_names[...] then we could eliminate almost all
> > of the disparate code. I haven't looked at the postscript stuff yet.
> Certainly, the standard colour table should be defined in one place
> only.
... and that one place should be a source (.c) file, not a header
file.
Declarations go in header files, definitions go in source files.
