[GRASS5] [bug #4311] (grass) shaded relief parameter checking
Hamish
hamish_nospam at yahoo.com
Wed Apr 19 23:32:16 EDT 2006
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4311
> > Subject: shaded relief parameter checking
> > There is a bug in r.shaded.relief where the input parameters are
> > checked, especially the azimuth.
> > the current version reads:
> > if test $alt -lt 0 -o $alt -gt 90
> > then
> > echo "Sorry, altitude must be greater than 0 and less than
> > 90"
> changed to "Sorry, altitude must be between 0 and 90"
> > exit 1
> > fi
> > if test $az -lt 0 -o $alt -gt 360
actually this was the error.
> > then
> > echo "Sorry, azimuth must be between 0 and 360"
> > exit 1
> > fi
Anyway, those checks should have been in the parameter setup as
#% options : 0-90
to let the parser do its job.
so I've moved them there for both 6.1 and 6.0.x CVS branches.
For this module out-of-bounds values don't fail, so 0-90 or 1-89 really
didn't matter to the output. I think the description was changed to
odd numbers to reflect the broken >,< tests?
also did a few more cleanups in the 6.1 branch. (record metadata, etc)
Hamish
