[GRASS5] extra file in 6.1-cvs src snapshot?
Markus Neteler neteler at itc.it
Sun Apr 23 12:19:22 EDT 2006
On Sat, Apr 22, 2006 at 06:21:49PM +1200, Hamish wrote:
> Hi,
> just grabbed today's snapshot & ran 'cvs update'.
> Two files not in CVS were in the .tgz,
> ChangeLog  (ok)
>  and
> swig/perl/Makefile.PL
> is Makefile.PL supposed to be in there? the header text says:
> # Generated automatically from Makefile.PL.in by configure.
If files are present in the snapshopt which should not
be there, then it is a bug
- either in the cleanup routine (make distclean)
- or the file needs to be removed from CVS.
Strange, because the main Makefile contains
        -rm -f swig/perl/Makefile.PL 2>/dev/null
in the distclean target.
Markus
