[GRASS5] The PATH of my own Grass module
Damiano Triglione damiano.triglione at polimi.it
Mon Apr 24 08:45:47 EDT 2006
I succeed in compiling my own GRASS module (temporary name: v.pregeo) but unfortunately it is only executable from its folder
~/grass-6.0.0/dist.i686-pc-linux-gnu/bin/
Here are my questions:
1- Is there a way to let my GRASS shell accept to run my v.pregeo as it does with the other predefind GRASS commands?
2- Is there a way to let me create the executable v.pregeo in the same directory of my source files (I mean: folder ./ ) instead of the default one?
3- How can I extend the environment variable $PATH by adding the folder ~/grass-6.0.0/dist.i686-pc-linux-gnu/bin/    ?
Thank you in advance,
Damiano
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060424/e39c9961/attachment.html
