[GRASS5] Suggested color function names
Mon Apr 24 12:10:20 EDT 2006
Hamish wrote:
> > BTW, I suggest removing the "set" field from the structure. Without
> > that field, the structure fits into 32 bits, and I suspect that most
> > functions would ignore that field anyhow.
> > In specific cases where you actually need a "set" field, you can use
> > a separate type, e.g.:
> > struct XRGBA_Color
> > 	int set;
> > 	RGBA_Color color;
> I could live without set,unset, but how to do you pass a color of "none"
> with just,
> typedef struct
>     unsigned char r, g, b, a;   /* red, green, blue, and alpha */
> } RGBA_Color ;
In what context does a colour of "none" make sense?
If you have a particular situation where you need additional
information other than just a colour, then create your own type for
that purpose.
There's no reason why everything which deals with colours needs to
carry that field around because something which uses colours needs it.
