[GRASS5] gis.m as default GUI
Wed Apr 26 05:11:54 EDT 2006
The new startup screen is great Michael.
on main screen and define new proj loc:
"Path to location" [nee database] -> "Path containing location(s)" ?
"Define new projection location" -> Define new projected location" ?
It'll be even better when we can simply double click a mapset name ;)
> For TclTk, I think replacing d.profile will be pretty straightforward.
> I'm have some ideas at least about how do to i.points and r.digit.
r.digit should be easy. The C version is already just a frontend that
writes to an ASCII file, which in the final step is fed to r.in.poly
creating the raster.
> It seems to me that nviz doesn't really need x11, but this is an
> opinion that is pretty ignorant of how it works internally (I've
> looked at the TclTk part but don't understand how it interacts with
> the C part or X11 part).
$ grep -rI '#include' visualization/nviz/ | grep X11 | wc -l
33
$ grep -rI '#include' visualization/nviz/ | grep X11 | cut -f1 -d: | uniq
visualization/nviz/src/do_zoom.c
visualization/nviz/src/interface.h
visualization/nviz/src/interface_old.h
visualization/nviz/src/tkInt4.0.h
visualization/nviz/src/tkUnixPort.h
visualization/nviz/src/tkWinPort.h
visualization/nviz/src/togl.c
visualization/nviz/src/togl.h
visualization/nviz/src/togl_cb.c
visualization/nviz/src/togl_flythrough.c
.. NVIZ needs X11, although it is full of:
#ifdef X11
#endif
which indicates that it could be possible to use if compiled without X11
support, perhaps with diminished functionality. I would guess NVIZ on
OSX without X11 would be doable, but might take some minor adjustments.
It probably needs to be made with:
./configure --without-x
Hamish
