[GRASS5] Re: [GRASSLIST:881] Re: Live Earthquake Map: GRASS/PHP
Hamish
hamish_nospam at yahoo.com
Thu Apr 27 06:03:24 EDT 2006
> I notice on the USGS page they center the world on 180 lon. May I
> suggest the same for your map? "g.region w=0 e=360"
> oops, that won't work anymore.. the >90 lat tweak broke it:
> G61> g.region w=0 e=360
> G61> d.redraw
> WARNING: Fixing subtle input data rounding error of east boundary
> (180>1e-06)
> G61> g.region -p
> (180>1e-06)
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 90N
> south: 90S
> west: 0
> east: 180E
> nsres: 0:05
> ewres: 0:05
> rows: 2160
> cols: 2160
> This needs to be fixed, lon needs to be able to go up to 360
> (remember mars example...)
> The previous code allowed you to go endlessly east or west on input,
> so just rip out east/west boundary fixes? (ie only keep >90lat fix)
I have disabled the epsilon check for LL e-w in CVS. Global wrapping is
much more important than accommodating a broken dataset.
Maybe we just need a better test:
if(fabs(180-lon) < GRASS_EPSILON) lon=180.0; sort of thing?
I don't really like that kind of trick much either.
Can you point to some test data?
Hamish
