[GRASS5] [bug #4356] (grass) d.m: d.rast.num fails when called
from 'Add comand layer'
Michael Barton
michael.barton at asu.edu
Thu Apr 27 23:31:43 EDT 2006
Are you using d.m or gis.m?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Thu, 27 Apr 2006 15:10:29 +0200 (CEST)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] [bug #4356] (grass) d.m: d.rast.num fails when called from
> 'Add comand layer'
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4356
> Subject: d.m: d.rast.num fails when called from 'Add comand layer'
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 2006-04-12
> 1. Add 'd.rast.num some_layer' using 'Add comand layer'.
> 2. When the following warning applies to d.rast.num, printed in the
> terminal...
> Current window size:
> rows: 154
> columns: 252
> Your current window setting may be too large.
> Cells displayed on your graphics window may be too
> small for cell category number to be visible.
> Do you wish to continue(y/n) [n]
> ...then an GUI error pops up:
> child process exited abnormally
> while executing
> "exec -- d.rast.num fdrp >@ stdout 2>@ stderr"
> ("eval" body line 1)
> invoked from within
> "eval exec -- $cmd >@ stdout 2>@ stderr"
> (procedure "runcmd" line 5)
> invoked from within
> "runcmd $cmd"
> (procedure "DmCmd::display" line 13)
> invoked from within
> "DmCmd::display $node"
> ("cmd" arm line 2)
> invoked from within
> "switch $type {
> group {
> DmGroup::display $node
> raster {
> DmRaster::display $node
> labels {
> DmLabels::display $node
> (procedure "Dm::display_node" line 6)
> invoked from within
> "Dm::display_node $n"
> (procedure "DmGroup::display" line 11)
> invoked from within
> "DmGroup::display "root" "
> (procedure "Dm::display" line 8)
> invoked from within
> "Dm::display"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
> (command bound to event)
> 3. Even if the region is small enough for the warning not to apply, using
> 'Zoom' tool in d.m results in the d.zoom GUI popping up, instead of running
> d.zoom per se.
> Maciek
> -------------------------------------------- Managed by Request Tracker
