[GRASS5] Re: v.clean rmsa option - what does it do ?
Moritz Lennert
mlennert at club.worldonline.be
Fri Apr 28 06:31:32 EDT 2006
Radim Blazek wrote:
> On 4/28/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
>>Radim Blazek wrote:
>>>On 4/27/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
>>>>Hello Radim,
>>>>Could you (or someone else who knows this) give a more thorough
>>>>explanation of what the 'rmsa' option of v.clean does (ideally in some
>>>>graphical form) ?
>>>>The man page says "remove small angles between lines at nodes", but I
>>>>don't really understand what this means and the French translators of
>>>>the manuals are trying to understand...
>>>If angle between 2 lines is smaller than threshold the lines
>>>are broken and the partialy merged.
>>Thanks for the explanation.
>>So if I understand correctly it does what is shown here:
>>http://geog-pc40.ulb.ac.be/grass/rmsa.pdf
> No, this can be don with 'prune' but tolerance is distance.
> I have attached picture of what rmsa does.
Thanks, that makes it much clearer. However, one more thing. In the
source code you write:
"It may happen that even if the angle between 2 boundaries at node is
very small, the calculated angle is 0 because of representation error."
And when one tries to set a threshold, the module says "WARNING:
Threshold for tool 1 may not be > 0, set to 0".
So, does this mean that this tool only works automatically for those
nodes where the calculation ends up with an angle of 0 ? The user cannot
change this threshold.
Should the description of the tool thus read something like this:
rmsa: remove small angles between lines at nodes (Only concerns angles
which are so small that the calculated angle is 0. The user cannot
change this threshold.)
Moritz
> Radim
>>i.e. converting the black line with a small angle into the new red line.
>>However, when I try to apply this to this line:
>>http://geog-pc40.ulb.ac.be/grass/rmsa_example.jpg
>>defined as follows in v.build:
>> > v.build brol
>>Building topology ...
>>3 primitives registered
>>Building areas: 100%
>>0 areas built
>>0 isles built
>>Attaching islands:
>>Attaching centroids: 100%
>>Topology was built.
>>Number of nodes : 4
>>Number of primitives: 3
>>Number of points : 0
>>Number of lines : 3
>>Number of boundaries: 0
>>Number of centroids : 0
>>Number of areas : 0
>>Number of isles : 0
>>in the following projection:
>> > g.proj -p
>>-PROJ_INFO-------------------------------------------------
>>name : Lambert Conformal Conic
>>proj : lcc
>>datum : bel72
>>a : 6378388
>>es : 0.0067226700
>>lat_1 : 49.83333333333334
>>lat_2 : 51.16666666666666
>>lat_0 : 90
>>lon_0 : 4.356939722222222
>>x_0 : 150000.01256
>>y_0 : 5400088.4378
>>no_defs : defined
>>-PROJ_UNITS------------------------------------------------
>>unit : metre
>>units : metres
>>meters : 1
>>Then whatever the threshhold value I set (going up to ridiculous values,
>>I continue to get 4 nodes, with 3 lines which look identical to the
>>original.
>>Am I still wrong in my understanding of rmsa, or is it something else ?
>>Moritz
