[GRASS5] error encountered in r.terraflow
abhay menon abhay.menon at gmail.com
Fri Apr 28 06:43:19 EDT 2006
hello all,
am still facing this problem.... even after updating the patch file..
r.terraflow December 2003
region size is 13593 x 15215
cell 960MBdata header compatible with region header
elevation stored as FLOAT (4B) WARNING: raster 960MBdata is of type
CELL_TYPE --you should use r.terraflow.short
STREAM temporary files in /var/tmp  (THESE INTERMEDIATE STREAMS WILL NOT BE
DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE
DELETE THESE FILES MANUALLY!)
SFD (D8) flow direction
D8CUT=999999986991104.000000
memory size: 400.00M (419430400) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
reading data from 960MBdata to stream /var/tmp/STREAM_kohqGU:
total elements=206817495, nodata elements=50042031
largest temporary files:
   FILL: 10.79G (11581779720) [206817495 elements, 56B each]
   FLOW: 11.68G (12542037120) [156775464 elements, 80B each]
Will need at least 23.36G (25084074240) space available in /var/tmp
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
finding nodata
relabeling nodata
MM warning: limit=419430400B. allocating 209608296B.  limit exceeded by
23602B.
23633B.
merging relabeled grid
MM warning: limit=419430400B. allocating 209567256B.  limit exceeded by
23558B.
23589B.
assigning preliminary directions
finding flat areas (plateaus and depressions)
plateau.cc:starting memscan
plateau.cc:memscan done
removing duplicate plateaus
MM warning: limit=419430400B. allocating 209567260B.  limit exceeded by
23574B.
23636B.
relabeling plateaus
23570B.
23601B.
generating plateau statistics
MM warning: limit=419430400B. allocating 209403100B.  limit exceeded by
23570B.
23601B.
assigning directions on plateaus
MM warning: limit=419430400B. allocating 209649312B.  limit exceeded by
19306B.
19368B.
generating watersheds and watershed graph
creating windows
warning: using slower scan
generateWatersheds
MM warning: limit=419430400B. allocating 209628776B.  limit exceeded by
10438B.
11182B.
file=/var/tmp/STREAM_UpisEN:cannot read!: Input/output error
r.terraflow: ./IOStream/include/ami_sort_impl.h:109: void
makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T =
waterWindowType, Compare = priorityCmpWaterWindowType]: Assertion `err ==
AMI_ERROR_NO_ERROR' failed.
Best Regrads
Abhay Menon
On 4/28/06, Shaun Walbridge <walbridge at nceas.ucsb.edu> wrote:
> Apologies, I forgot to re-attach the patch to this list.  The only
> changes I've found necessary are those couple spots in ami_stream.h.
> We've successfully run Terraflow on 4GB+ datasets after the swap to
> fseeko/ftello.
> Cheers,
> Shaun
> --- ami_stream.h        2004-11-09 05:29:58.000000000 -0800
> +++ ami_stream.h.edit   2006-04-27 10:44:48.000000000 -0700
> @@ -394,8 +394,8 @@
>     seek_offset = offset * sizeof(T);
> -  if (fseek(fp, seek_offset, SEEK_SET) == -1) {
> -    cerr << "AMI_STREAM::seek offset=" << seek_offset << "failed.\n";
> +  if (fseeko(fp, seek_offset, SEEK_SET) == -1) {
> +    cerr << "AMI_STREAM::seek offset=" << seek_offset << " failed.\n";
>     assert(0);
>     exit(1);
> @@ -463,7 +463,7 @@
>   assert(fp);
>   //if we go past substream range
> -  if ((logical_eos >= 0) && ftell(fp) >= sizeof(T) * logical_eos) {
> +  if ((logical_eos >= 0) && ftello(fp) >= sizeof(T) * logical_eos) {
>     return AMI_ERROR_END_OF_STREAM;
>   } else {
> @@ -489,7 +489,7 @@
>   assert(fp);
>   } else {
> @@ -512,7 +512,7 @@
>   assert(fp);
>   } else {
> @@ -532,7 +532,7 @@
>   assert(fp);
>   } else {
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060428/ead1da27/attachment.html
