[GRASS5] Proposal: RFC 1: Project Steering Committee Guidelines
Michael Barton michael.barton at asu.edu
Fri Apr 28 08:14:56 EDT 2006
I agree with Helena. All the suggestions I've seen to date are potentially
workable. I like the the idea +/- as it's proposed since I may not have the
time, interest, or expertise to weigh in on many proposals, but will
definitely want to add my +1 cents on a few. However, we'll probably need to
simply try out something and see what works...and probably will need to
tweak it somewhat. Since I'd like to see this in operation, I'm willing to
be flexible. If there is one set of suggestions that most people are willing
to try, I'll go along with it. I'm not being lazy, but don't have as much
time to think about this as it deserves at the moment and don't want to hold
up the process.
Brad, I DO favor a PSC. You must have confused my comments with someone
else.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Helena Mitasova <hmitaso at unity.ncsu.edu>
> Date: Thu, 27 Apr 2006 23:32:45 -0400
> To: Markus Neteler <neteler at itc.it>
> Cc: grass5 list <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] Proposal: RFC 1: Project Steering Committee Guidelines
> Markus,
> you may want to add some clarification when a proposal is needed to
> make a change
> (it is partially implied by a section about when vote is needed, but
> maybe that should be defined somewhere
> at the beginning of the detailed process description - or you can
> just say "When is the proposal and vote required").
> How the proposal should look like?
> Is a short email to developers list, as we have now enough - I hope
> it is.
> Regarding Radim's comments - let us try to follow the suggestions
> from Markus and Frank modeled
> after other projects to see whether it works for us, we can always
> change it / modify later
> Helena
> Helena Mitasova
> Dept. of Marine, Earth and Atm. Sciences
> 1125 Jordan Hall, NCSU Box 8208,
> Raleigh NC 27695
> http://skagit.meas.ncsu.edu/~helena/
> On Apr 27, 2006, at 11:01 PM, Michael Barton wrote:
>> This looks OK to me.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: Markus Neteler <neteler at itc.it>
>>> Date: Wed, 26 Apr 2006 21:20:26 +0200
>>> To: <grass5 at grass.itc.it>, GRASS user list <grasslist at baylor.edu>
>>> Subject: [GRASS5] Proposal: RFC 1: Project Steering Committee
>>> Guidelines
>>> Dear all,
>>> to better illustrate the idea of a GRASS Project Steering
>>> Committee (PSC),
>>> I have drafted a document:
>>>  http://mpa.itc.it/markus/grass61progman/rfc/rfc1_psc.html
>>>  In CVS: rfc/RFC1_PSC.dox
>>> The content is heavily inspired by the related documents from the
>>> GDAL, Mapserver and Mapbender projects.
>>> As stated in this document: It is desired to keep the
>>> administrational
>>> overhead as low as possible. However, for strategic decisions a more
>>> formal approach for decisions is needed.
>>> Please take a look and comment since it is a Request for Comments
>>> (RFC).
>>> Best regards
>>>  Markus
>>> Markus Neteler     <neteler itc it>       http://mpa.itc.it
>>> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
>>> MPBA - Predictive Models for Biol. & Environ. Data Analysis
>>> Via Sommarive, 18        -       38050 Povo (Trento), Italy
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
