[GRASS5] [bug #4363] (grass) error in r.terraflow
Request Tracker
grass-bugs at intevation.de
Fri Apr 28 08:23:13 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4363
Subject: error in r.terraflow
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: grass-6.1.cvs_src_snapshot_2006_04_15
Hi this is Abhay Menon, I am facing a problem with r.terraflow module.
I am using Fedora Core 4 as the OS. also I compiled the module with --enable-largefile switch. and my dataset in ESRI Ascii Raster Grid.
as soon as it starts is generating the watersheds and watershed graph.
the following message is displayed.
---quote-----------
generating watersheds and watershed graph
creating windows
warning: using slower scan
generateWatersheds
MM warning: limit=419430400B. allocating 209628776B. limit exceeded by 10438B.
MM warning: limit=419430400B. allocating 209628776B. limit exceeded by 11182B.
file=/var/tmp/STREAM_UpisEN:cannot read!: Input/output error
r.terraflow: ./IOStream/include/ami_sort_impl.h:109: void makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T = waterWindowType, Compare = priorityCmpWaterWindowType]: Assertion `err == AMI_ERROR_NO_ERROR' failed.
---unquote-----------
Thanks!
-------------------------------------------- Managed by Request Tracker
