[GRASS5] r.terraflow patch
Brad Douglas rez at touchofmadness.com
Fri Apr 28 18:39:09 EDT 2006
On Fri, 2006-04-28 at 11:06 -0400, Andrew Danner wrote:
> Shaun,
>  Thanks! Can someone patch the CVS tree with Shaun's patch? It is
> certainly needed for large file support.
I'll try to get it committed this weekend.  I've been doing some work on
the module anyway.  I'll see if I can isolate some of the issues
mentioned by Abhay.
Brad Douglas <rez touchofmadness com>                      KB8UYR
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
