[GRASS-dev] Re: d.vect.thematic creates outtxt.txt file which is not erased
Moritz Lennert mlennert at club.worldonline.be
Tue Aug 1 06:24:44 EDT 2006
Michael Barton wrote:
> I can't see any reason for this line. So I commented it out and committed
> the change to the cvs. Let me know if it messes up anything I didn't see.
I now get the following error, but only in a new location, not in
already existing ones. Strange...
couldn't open
"/home/mlennert/GRASS/DATA/BE/mlennert/.tmp/geog-pc40/gismlegend.txt":
no such file or directory
couldn't open
     while executing
"open $legfile r"
     (procedure "GmThematic::tleg_item" line 12)
     invoked from within
"GmThematic::tleg_item $mon $id"
     (procedure "GmThematic::display" line 78)
     invoked from within
"GmThematic::display $node $mod"
     ("thematic" arm line 2)
     invoked from within
"switch $type {
         group {
             GmGroup::display $node $mod
		raster {
			GmRaster::display $node $mod
		labels {
			GmLabels::disp..."
     (procedure "GmTree::display_node" line 7)
     invoked from within
"GmTree::display_node $n $mod"
     (procedure "GmGroup::display" line 25)
     invoked from within
"GmGroup::display "root" $mod"
     (procedure "MapCanvas::runprograms" line 30)
     invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
     (procedure "MapCanvas::drawmap" line 43)
     invoked from within
"MapCanvas::drawmap $mon"
     (procedure "MapCanvas::display_server" line 9)
     invoked from within
     ("after" script)
