[GRASS-dev] v.extract and sqlite-db
Stephan Holl
holl at gdf-hannover.de
Wed Aug 2 07:32:20 EDT 2006
Dear devs,
playing with sqlite as attribute-storage I found out, that the ID needs
to be an integer. I tried with this[1] sample
spearfish-sqlite-attributedb which has a 'numeric' type for ID.
v.db.connect does not complain as long as you do not use v.extract with
a where-statement to extract parts of your data.
The resulting dataset is broken afterwards.
To reproduce in spearfish60:
wget [1]
g.copy vect=soils at PERMANENT,soils_cp
v.db.connect -o map=soils_cp table=soils_legend
database=./soils_legend.db driver=sqlite key=id
v.db.select soils_cp|head
id|shortname|longname
0.000000|no data|no data
1.000000|AaB|Alice fine sandy loam, 0 to 6
v.extract in=soils_cp out=soils_steep type=area where="longname LIKE
'%steep%'"
Load cats from the database (table = soils_legend, db
= ./soils_legend.db). 5 cats loaded from the database
Building topology ...
194 primitives registered
Building areas: 100%
39 areas built
16 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 171
Number of primitives: 194
Number of points : 0
Number of lines : 0
Number of boundaries: 164
Number of centroids : 30
Number of areas : 39
Number of isles : 16
Number of areas without centroid : 9
Writing attributes ...
Layer 1
ERROR: Column 'id' is not integer
GRASS 6.1.cvs (spearfish60):
v.info soils_steep
ERROR: Cannot open old vector soils_steep at lausanne_db on level 2
I would suggest, that the driver does not create the dataset, if the
id-column is a non-integer.
Using a table with an int id-column works fine though.
Best
Stephan
[1] http://mpa.itc.it/grasstutor/scripts/soils_legend.db
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
