[GRASS-dev] Re: GRASS bugs
Maciej Sieczka tutey at o2.pl
Wed Aug 2 10:05:53 EDT 2006
Paolo Cavallini napisa?(a):
> Maciej Sieczka ha scritto:
>  > I agree that the BT is a bit PR tool whether we like it or not...
> Glad we agree.
>>>> The best bug reporting tool I'm using is Trac, used eg by qgis:
>>>> http://svn.qgis.org/trac/report/
>>>> very easy to use, powerful, and reports can be customized easily. Could
>>>> we move to this?
>>> (Bernard has recently told that a move to Gforge at
>>> http://wald.intevation.org/ is planned.)
>>> Bernhard, is there a time schedule for that yet?
>>> How would Gforge compare to Trac?
> I used both, and found trac far more straightforward.
>>> I personally don't like Trac's WIKI like format; it makes reporting bugs
>>> over complicated, which might scare off naive users. The WIKI formatting
>>> should be only an addition to allow formatting when needed. It should
>>> not not the requirement only to fill in a 10 word report.
> ? You can enter straight text, I do not see problems here.
I at least recall there are is an issue with linebreaks in Trac. Eg, if
you do:
1. Point one.
2. Point two.
it will become;
1. Point one.2. Point two.
You have to remember to do it like:
1. Point one.
2. Point two.
to avoid that.
More gotchas I don't remember now.
>>> Let's hold off planning the bug fiest schedule until the issues here are
>>> sorted out.
> Agreed.
*And* we need more C programmers. And tcltk propably too.
Maciek
