[GRASS-dev] v.digit startup error from -n position
Michael Barton
michael.barton at asu.edu
Wed Aug 2 13:38:55 EDT 2006
OK. Looking through to the very bottom of the thread, there appears to be
some confusion about what is meant by GUI.
If v.digit is having a problem with a new vector when run from the toolbar
button in gism, it is one thing. This SHOULD be OK. I've checked the code
and it is written...
v.digit -n map=new_map
... as Glynn indicated. If this is where the problem lies, then, there is
some other kind of issue.
Glynn also noted, however, that in the auto-generated GUI dialogs, this is
being written as...
v.digit map=new_map -n
This causes a problem because the -n is misinterpreted by TclTk as a flag in
the TclTk command. So if the problem arises when v.digit is run from a menu
or the dialog is started from the CLI by simply typing v.digit, then THIS is
where the problem lies.
Generically, the GRASS flags should come before any other arguments it
seems. I don't know where this is coded, but Cedric should know.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Wed, 02 Aug 2006 19:17:34 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Markus Neteler <neteler at itc.it>, GRASS developers list
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] v.digit startup error from -n position
> Markus, Michael,
> https://intevation.de/rt/webrt?serial_num=4604
> Maciek
