[GRASS-dev] PATCH: debugging.txt
Brad Douglas
rez at touchofmadness.com
Fri Aug 4 00:40:21 EDT 2006
On Fri, 2006-08-04 at 03:59 +0100, Glynn Clements wrote:
> Brad Douglas wrote:
> > Any suggestions/objections to the attached patch?
> > + * After running 'configure', include/Make/Platform.make should be
> > + edited and append -pg to LINK_FLAGS
> No need; just add -pg to LDFLAGS when running configure, e.g.
> CFLAGS='-pg -O2' LDFLAGS=-pg ./configure ...
Ah! Thank you. That makes things a bit easier to document. Changes
attached.
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060803/34a16107/debug.bin
