[GRASS-dev] [bug #4960] (grass) gis.m has menu entries for
nonexisting modules
Māris Nartišs
maris.gis at gmail.com
Fri Aug 4 03:49:34 EDT 2006
as I'm not coder but simple user, I can not understand why letting program to
fail with user UNfrendly error is good point. If there could be discussion
about showing or hiding unavailable menu items*, then I don't see any reason
why there should be no check against does such module (file) exists.
And second - I never understood how RT works (yea, it's definitely not
Bugzilla), so You probably missed my proposed 3line quickfix. So - please
take a look at it and say a word - does such user friendly error handling is
bad for GRASS?
Just my 3c to make GRASS better,
Maris.
On Friday 04 August 2006 01:19, Glynn Clements wrote:
> Also, testing whether an executable is present isn't the same thing as
> testing whether or not it can actually be run. It's arguably better to
> treat all such problems in a similar manner (attempt to run the module
> and show any specific errors to the user) than to treat specially the
> case where the executable is absent.
Here are my first 3 lines in tcl/tk.
W0ps - just found bug - it will fail IF $program already contains full path to
executable ($GISBASE/etc/gm/scripts/FOO).
--- gui/tcltk/gis.m/runandoutput.tcl.orig 2006-07-22
12:29:48.000000000 +0300
+++ gui/tcltk/gis.m/runandoutput.tcl 2006-08-03 23:09:43.000000000 +0300
@@ -65,10 +65,15 @@
proc run_ui {cmd} {
- global dlg path
+ global dlg path env
set program [lindex $cmd 0]
+ if { ![file executable $env(GISBASE)/bin/$program] } {
+ tk_messageBox -icon error -message [G_msg "Sorry, your GRASS
installation lacks module \"$program\""]
+ return
set code [exec -- $program --tcltk]
set path .dialog$dlg
