[GRASS-dev] creating new modules
Kirk R. Wythers kwythers at umn.edu
Fri Aug 4 10:35:47 EDT 2006
I am interested in porting an ecosystem model (carbon balance model)
to a grass module. Currently my simulation model consists of 4 .cpp
files (essentially a "main" file, a vegetation parameters file, and
climate file, and a io file), and then 3 associated header files. I
found the link:
http://grass.itc.it/intro/modelintegration.html
Which describes simulation models that have been incorporated into
grass.
But could also use some general advice as to "best practices" new
module structure. Has anyone put together a grass module howto?
Perhaps the programmers guide? I've been digging around on the wiki,
but haven't found what I'm looking for yet. What I am basically
asking for is to be pointed to a well done example that I should
follow as "simulation model module template"
Any suggestions?
Thanks,
Kirk
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060804/a410d0dd/attachment.html
