[GRASS-dev] Bugs vs. wishes
Florian Kindl
florian.kindl at uibk.ac.at
Sat Aug 5 18:08:07 EDT 2006
On 05.08.2006, at 23:19, Markus Neteler wrote:
> In the HTML source code is used "wish6"
> <td>
> <select name="area">
> <option value="grass6">bug in GRASS 6.0/6.1
> <option value="wish6">wish for GRASS 6.1
> <option value="doc-grass6">docs bug in GRASS 6
> <option value="doc-wish-grass6">docs wish for GRASS 6
> <option value="grass5.4">bug in GRASS 5.4
> </select>
> </td>
> which should be ok. If it doesn't work I suspect something in the
> bugtracker not functioning (any more).
RT stores it in the "Area" wish6. So far, this is correct.
However, it is forwarded to grass-devel with Subject: [bug #nnnn]
\flo.
